Hi All,
I'm checking out an ArcGIS Runtime license from our ArcGIS Online account using the code below that is copied from ArcGIS Runtime SDK for iOS documentation:
//get the users license info from the portal
portal.fetchLicenseInfo { (licenseInfo,error) in
guard let error = error {
print("Error fetching user's licenses... \(error)")
return
//set the license using the Named User's licenseInfo
do {
let result = try AGSArcGISRuntimeEnvironment.setLicenseInfo(licenseInfo!)
} catch let error as NSError {
print("error: \(error.localizedDescription)")
//The app is now licensed
// Save the license information so that the app can be started and licensed offline
// In this example the licenseDictionary is stored in keychain
var licenseDictionary: NSDictionary?
do {
licenseDictionary = try licenseInfo?.toJSON() as! NSDictionary?
} catch {
print("LicenseInfo not available")
let keychainItem = AGSKeychainItem(identifier: "com.your_org.your_app_name", accessGroup: nil, acrossDevices: false)
keychainItem.writeObject(toKeychain: licenseDictionary!, completion: { (writeError) in
if let error = writeError {
print("Error writing to the Keychain... \(error)")
The problem is that the completion closure of the portal.fetchLicenseInfo() method never gets invoked and as a result I never get a license or an error...
However, I can get a valid license from the portal property: portal.portalInfo?.licenseInfo, but 'licenseInfo' is deprecated: This property has been replaced by `AGSPortal#fetchLicenseInfoWithCompletion:` from Xcode.
Does anybody have any idea please? I'm using SDK 100.10.
Shimin
