Hello everyone,
I am having an annoying problem concerning a Feature Layer. The Feature Layer was published using a Datastore (Database) connection to a PostgreSQL Database. The publishing process worked fine and the layer got a (random?) symbology. Now I want to change that symbology.
When going into the "Visualisation" Tab of the portal item I can change the symbology and save the layer. The changes are present when I open the layer in a map viewer and also in the items JSON. In the REST interface however the "Drawing Info" does not reflect the changes I made. So when integrating the service I still get the old symbology.
I tried updating the definition of the layer using python as I did with other (but hosted) feature layers, but end in an error:
Access to admin resources are not allowed.
(Error Code: 403)
Has anyone ever had that problem and knows how to fully update the symbology? Thanks for any hints.
