There is a logged bug with the attribute table in web app builder. I am trying to calculate lat and long using an arcade expression. The coordinates show up in the popup window but it crashes the attribute table causing the data not too load. I have tried with smaller datasets and get the same issue, has anyone been able to find a workaround or alternative solution. We would like to export to csv and have lat and long in the export.
thanks in advance.
https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDEzMTk1OQ==
BUG-000131959
Commenting here because I am experiencing the same issue.
Did you find a resolution or work-around? Appears the bug is still unresolved.
unfortunately not, ended up adding lat and long into the feature class as fields and using the smart widget to keep it updated.
Los miembros que hayan iniciado sesión pueden publicar, seguir novedades y mucho más. ¿Eres nuevo por aquí? Regístrate gratis.
