Up until recently, I have had no issues with using the Dropped Pin function to add a new feature via "Collect Here". I recently added the GPS Metadata fields to the data and I feel this is causing the issue. When ever I try to drop a pin and add a new point using "Collect Here", upon submission I receive the message;
Unable to submit
Geodatabase data type mismatch.
I am not receiving this error when collecting a new point through the normal operation of adding a new point. Because of this, I did some additional testing using the "Collect Here" method and figured out when I "UPDATE POINT" utilizing "Use Target Location" or "Start Averaging" I am then able to submit.
None of the GPS Metadata fields are required (to my knowledge). What may be causing this hangup?
