Hello!
I am trying to replace the values for variables in an Arcade expression, however, it fails when I replace the numbers for variables.
Can you please, help me to fix the expression?
arcpy.CalculateField_management(Image_classified, "Dens",
"when($feature.gridcode == 1, 1.51, $feature.gridcode == 2,1.48, $feature.gridcode == 3, 5.03, 0)", "ARCADE")
I tried
a=1.51
b=1.48
c=5.03
"when($feature.gridcode == 1, a, $feature.gridcode == 2,b, $feature.gridcode == 3, c, 0)", "ARCADE")
and gave me this error:
File "C:\Users\milop\Documents\ArcGIS\Projects\Image_processing_110621\model_summwhitin_230621.py", line 103, in <module>
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py", line 5209, in CalculateField
raise e
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py", line 5206, in CalculateField
retval = convertArcObjectToPythonObject(gp.CalculateField_management(*gp_fixargs((in_table, field, expression, expression_type, code_block, field_type), True)))
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 511, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: ERROR 002717: Invalid Arcade expression, Arcade error: Object not found a...
