Hello, I am trying to create a large .mmpk ~10GB for use with Field Maps. Since the file is so large and takes so long to process I've been adding a few layers and processing a new mmpk to test. Every iteration has worked until yesterday when I added my final layers. Now I am getting an error that reads, "Unable to Open Map. An error occurred opening the map. URL must not be null or empty." How do I get past/fix this so I can open the mmpk?
I've removed the recently added layers to get back to the last version that works and reprocessed the package but am now still getting the same error. I am sideloading the .mmpk on to the device. Thanks in advance for any advice!
