Hi All,
Once I closed the ArcGIS Pro (version 2.8) - getting below error message.
Managed Debugging Assistant 'DisconnectedContext' : 'Transition into COM context 0xdaa009c0 for this RuntimeCallableWrapper failed with the following error: The object invoked has disconnected from its clients. (Exception from HRESULT: 0x80010108 (RPC_E_DISCONNECTED)). This is typically because the COM context 0xdaa009c0 where this RuntimeCallableWrapper was created has been disconnected or it is busy doing something else. Releasing the interfaces from the current COM context (COM context 0xdaa002d0). This may cause corruption or data loss. To avoid this problem, please ensure that all COM contexts/apartments/threads stay alive and are available for context transition, until the application is completely done with the RuntimeCallableWrappers that represents COM components that live inside them.'
I have cross-checked my code and there are no threads created without await and we are coming out from the process after completion of these await statement.
For ex,
await QueuedTask.Run(() => { activateSelectToolAsync(); });
return false;
Is there any way - we can see which process is creating issue? Appreciate your help on this.
