| DEBUG | Container 0b2a4111cef23cbfa5c6d1ef87e3882747e17aac1d0ee2c03b84a6346bf95a6a is not running. | 2021-05-11T12:39:44,560 | 157b1fff-9bd8-464f-8140-5b50767af007 | 9999 |
| DEBUG | com.esri.arcgis.carbon.admin.AdminException: Container 0b2a4111cef23cbfa5c6d1ef87e3882747e17aac1d0ee2c03b84a6346bf95a6a is not running. at com.esri.arcgis.turing.admin.system.ContainersManager.launchContainer(ContainersManager.java:384) at com.esri.arcgis.turing.admin.notebooks.NotebooksManager.openNotebookLocal(NotebooksManager.java:401) at com.esri.arcgis.turing.admin.notebooks.NotebooksManager.openNotebook(NotebooksManager.java:212) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.base/java.lang.reflect.Method.invoke(Unknown Source) at com.esri.arcgis.carbon.admin.system.AsyncJobsManager$a.run(AsyncJobsManager$a.java:144) at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at java.base/java.lang.Thread.run(Unknown Source)Caused by: com.esri.arcgis.carbon.admin.AdminException: Container 0b2a4111cef23cbfa5c6d1ef87e3882747e17aac1d0ee2c03b84a6346bf95a6a is not running. at com.esri.arcgis.turing.admin.system.ContainersManager.a(ContainersManager.java:1806) at com.esri.arcgis.turing.admin.system.ContainersManager.launchContainer(ContainersManager.java:331) ... 10 moreCaused by: java.lang.IllegalStateException: Container 0b2a4111cef23cbfa5c6d1ef87e3882747e17aac1d0ee2c03b84a6346bf95a6a is not running. at org.mandas.docker.client.DefaultDockerClient.execCreate(DefaultDockerClient.java:1374) at com.esri.arcgis.turing.admin.system.ContainersManager.a(ContainersManager.java:1774) ... 11 more | 2021-05-11T12:39:44,560 | 157b1fff-9bd8-464f-8140-5b50767af007 | 9999 |
| INFO | Docker container successfully launched. | 2021-05-11T12:39:38,411 | 157b1fff-9bd8-464f-8140-5b50767af007 | 5015 |
| DEBUG | samplesData location is set to /home/user/arcgis/notebookserver/usr/directories/arcgisworkspace/samplesdata | 2021-05-11T12:39:35,9 | 157b1fff-9bd8-464f-8140-5b50767af007 | 9999 |
| DEBUG | Binding container to directory path: /home/user/arcgis/notebookserver/framework/runtime/tomcat/bin/\\NAS1\Data --> /arcgis/directories/Nas1_Data | 2021-05-11T12:39:35,34 | 157b1fff-9bd8-464f-8140-5b50767af007 | 9999 |
| DEBUG | Binding container to directory path: /home/user/arcgis/notebookserver/framework/runtime/tomcat/bin/\\NAS1\Data2 --> /arcgis/directories/Nas1_Data2 | 2021-05-11T12:39:35,34 | 157b1fff-9bd8-464f-8140-5b50767af007 | 9999 |
| DEBUG | Binding container to directory path: /home/user/arcgis/notebookserver/usr/directories/arcgisworkspace/samplesdata --> /arcgis/samplesdata | 2021-05-11T12:39:35,33 | 157b1fff-9bd8-464f-8140-5b50767af007 | 9999 |
| DEBUG | Binding container to directory path: /home/user/arcgis/notebookserver/usr/directories/arcgisworkspace/zzzz --> /arcgis/home | 2021-05-11T12:39:35,13 | 157b1fff-9bd8-464f-8140-5b50767af007 | 9999 |
| DEBUG | docker run -d --name b963e8d4632c4e62b8b6d595d31ffd90 -e "NB_AUTH_FILE=/arcgis/home/.nb_auth_file_28e57816efbe" -e "JSAPI_CDN=null" -p 30001:8888 --cpu-quota=200000 --cpu-period=100000 --shm-size=2147483648 --memory-swap=0 -m=6442450944 --hostname=28e57816efbe -v /home/user/arcgis/notebookserver/usr/directories/arcgisworkspace/zzzz:/arcgis/home -v /home/user/arcgis/notebookserver/usr/directories/arcgisworkspace/samplesdata:/arcgis/samplesdata:ro -v /home/user/arcgis/notebookserver/framework/runtime/tomcat/bin/\\NAS1\Data2:/arcgis/directories/Nas1_Data2 -v /home/user/arcgis/notebookserver/framework/runtime/tomcat/bin/\\NAS1\Data:/arcgis/directories/Nas1_Data e835875a091bbc5a9a02569ef3419b7408307227e0e99a47c220ca33072e712e start-notebook.sh --NotebookApp.base_url=/notebook/notebooks/b963e8d4632c4e62b8b6d595d31ffd90 --NotebookApp.notebook_dir=/arcgis --JupyterApp.config_file=/arcgis/home/.jupyter_notebook_config.py --NotebookApp.log_level=10 --NotebookApp.certfile=/arcgis/home/.xyz.crt --NotebookApp.keyfile=/arcgis/home/.xyz.key --NotebookApp.shutdown_no_activity_timeout=43200 | 2021-05-11T12:39:35,103 | 157b1fff-9bd8-464f-8140-5b50767af007 | 9999 |
| DEBUG | User for this container request is zzzz | 2021-05-11T12:39:34,973 | 157b1fff-9bd8-464f-8140-5b50767af007 | 9999 |
| FINE | jupyter_notebook_config.py copied successfully. | 2021-05-11T12:39:34,778 | 157b1fff-9bd8-464f-8140-5b50767af007 | 5027 |
| DEBUG | Setting permissions on .jupyter_notebook_config.py in the user workspace dir. | 2021-05-11T12:39:34,777 | 157b1fff-9bd8-464f-8140-5b50767af007 | 9999 |
| DEBUG | Setting permissions on .nbs.pem in the user workspace dir. | 2021-05-11T12:39:34,757 | 157b1fff-9bd8-464f-8140-5b50767af007 | 9999 |
| DEBUG | Exporting the keystore to PKCS12 | 2021-05-11T12:39:32,669 | 157b1fff-9bd8-464f-8140-5b50767af007 | 9999 |
| FINE | Copied SSL certificates for user : 'xyz' | 2021-05-11T12:39:32,618 | 157b1fff-9bd8-464f-8140-5b50767af007 | 5025 |
| DEBUG | Setting permissions on .xyz.key in the user workspace dir. | 2021-05-11T12:39:32,618 | 157b1fff-9bd8-464f-8140-5b50767af007 | 9999 |
| DEBUG | Setting permissions on .xyz.crt in the user workspace dir. | 2021-05-11T12:39:32,615 | 157b1fff-9bd8-464f-8140-5b50767af007 | 9999 |
