Our code for deleting inactive users on AGOL is failing on the user.delete() command after upgrade to Pro 2.7.0 using the python api 1.8.4. The final return is "Exception: not licensed by user (Error Code: 400)" with full return in attached file. These users do not have content or own groups or have any special licensing. To verify, a new test user with no content, etc. was created and exhibited the same issue. Upgraded to Pro 2.7.3 and api 1.8.5 did not solve the issue. Going back to the base python 3.7.9 install from the ve also did not change the error. As it seems related to entitlements, I added a license to the user to see if the error changed, it didn't. The user can be deleted manually via AGOL, and a different machine running Pro 2.3.2 and I believe api 1.6.2, can run this command without error. None of our other python api commands seem to be failing. Ideas on what I'm missing?
