Good morning. I'm having an issue on correctly relating a BIM model, which was referred to internal GIS data to the basemap, in order to display it properly. With the command Elevate to ground the BIM model correctly displays on the top of the basemap, but with the fact that i have an underground floor i'm trying to give a negative offset to that so it display properly only the outer floors. I realized that i can modify the offset of the single feature classes inside the BIM model, but this would be a long process, is there a way to modify the elevation of the entire BIM workspace at once, due to the fact that right now that option is greyed out?
Thanks in advance.
