This is our newly upgraded parcel and real estate viewer. Our users' workflow has been to search for an address (94 Lincoln St), select it from the Results tab, view the Property Sheet tab, hit the Map tab, select a neighboring parcel, hit View Property Details on the pop-up. Hit the Map tab again and select the next neighbor. But every time we return to the map, it's hung on the original result, 94 Lincoln St. It won't release that parcel unless we start a new search. Each subsequent click on the map that highlights and shows pop up should release and supersede 94 Lincoln St. My developer says it's not in his code, it's in the IIS settings on the app server or the reverse proxy server. I believe it's in the code... _app\scripts\LayoutSettings or MapViewer or _Layout.cshtml. Can anyone suggest a property or phrase or an IIS setting that would govern the refresh or clearing of the Results parcel? Thank you. Allan
Windows Server 16, SQL Server 16, ArcGIS Enterprise 10.7.1. Rest Service
