Hello all,
Some time after upgrading to Arc Pro 2.7 (now on 2.7.2) I lost the ability to install anything via the python package manager. In particular I've been trying to re-install Spyder ('cause of course it didn't install with the Arc Pro update). After cloning the default environment as usual and trying to install spyder using "Add Packages", it just goes away for a short bit and nothing gets installed. So I went to the command line (using "proenv.bat), and tried installing it from there, but get the following error:
"CondaVerificationError: The package for pip located at C:\Users\ringoc\AppData\Local\ESRI\conda\pkgs\pip-21.0.1-py37haa95532_0
appears to be corrupted. The path 'Lib/site-packages/pip-21.0.1-py3.7.egg-info/PKG-INFO'
specified in the package manifest cannot be found."
I've uninstalled/reinstalled Arc Pro a couple of times, deleting the old cloned-environment folder each time, but have gotten the same result.
Any ideas anyone?
Thanks for any input!
