I'm working on a subdivision that involves several layers. Midway through a traverse, I exported a traverse from Pro (to use as a save point) and then later I found there was an error since it did not close. I started over and imported the saved traverse, however none of the line layers were retained. It would be great if the line layers could be retained/saved so I wouldn't have to individually change each line layer.
