I am trying to include user authentication into a webpage. I want to use `BeginOAuth2` method from the rest-js library.
I have found some examples with the property `popup` set to `true`, for example, https://github.com/Esri/arcgis-rest-js/tree/master/demos/oauth2-browser
I do not want to redirect the user to any other site, just open the authentication in the same window and then go back to the original page (storing the obtained token in the local storage). However, I can't figure out how to deal with the `redirect uri` in those settings. Do you have any exemplary code snippets which deal with the `popup` set to false? Also, do I also need to use the `CompleteOAuth2` method to get the token?
