Hallo, im newbie about arcgis api js, i want to question, how to filter by multiple attributes, in below im to try use this sample code by arcgis,
https://developers.arcgis.com/javascript/latest/sample-code/featurefilter-attributes/
but this sample, just filter by one filter, i want to filter by multiple atributes and show on map, example i want to filter by winter and spring and show it together on map, thnks
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8" />
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
<title>Filter features by attribute | Sample | ArcGIS API for JavaScript 4.18</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.18/esri/themes/light/main.css" />
<script src="https://js.arcgis.com/4.18/"></script>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
#seasons-filter {
height: 160px;
width: 100%;
visibility: hidden;
.season-item {
width: 100%;
padding: 12px;
text-align: center;
vertical-align: baseline;
cursor: pointer;
height: 40px;
.season-item:focus {
background-color: dimgrey;
.season-item:hover {
#titleDiv {
padding: 10px;
#titleText {
font-size: 20pt;
font-weight: 60;
padding-bottom: 10px;
</style>
<script>
require([
"esri/views/MapView",
"esri/Map",
"esri/layers/FeatureLayer",
"esri/widgets/Expand"
], function (
MapView, Map, FeatureLayer, Expand
let floodLayerView;
// flash flood warnings layer
const layer = new FeatureLayer({
portalItem: {
outFields: ["SEASON"]
const map = new Map({
basemap: "gray-vector",
layers: [layer]
const view = new MapView({
map: map,
container: "viewDiv",
center: [-98, 40],
zoom: 4
const seasonsNodes = document.querySelectorAll(`.season-item`);
const seasonsElement = document.getElementById("seasons-filter");
// click event handler for seasons choices
seasonsElement.addEventListener("click", filterBySeason);
// User clicked on Winter, Spring, Summer or Fall
// set an attribute filter on flood warnings layer view
// to display the warnings issued in that season
function filterBySeason(event) {
const selectedSeason = event.target.getAttribute("data-season");
floodLayerView.filter = {
where: "Season = '" + selectedSeason + "'"
view.whenLayerView(layer).then(function (layerView) {
// flash flood warnings layer loaded
// get a reference to the flood warnings layerview
floodLayerView = layerView;
// set up UI items
seasonsElement.style.visibility = "visible";
const seasonsExpand = new Expand({
view: view,
content: seasonsElement,
expandIconClass: "esri-icon-filter",
group: "top-left"
//clear the filters when user closes the expand widget
seasonsExpand.watch("expanded", function () {
if (!seasonsExpand.expanded) {
floodLayerView.filter = null;
view.ui.add(seasonsExpand, "top-left");
view.ui.add("titleDiv", "top-right");
</script>
</head>
<body>
<div id="seasons-filter" class="esri-widget">
<div class="season-item visible-season" data-season="Winter">Winter</div>
<div class="season-item visible-season" data-season="Spring">Spring</div>
<div class="season-item visible-season" data-season="Summer">Summer</div>
<div class="season-item visible-season" data-season="Fall">Fall</div>
</div>
<div id="viewDiv"></div>
<div id="titleDiv" class="esri-widget">
<div id="titleText">Flash Floods by Season</div>
<div>Flash Flood Warnings (2002 - 2012)</div>
</div>
</body>
</html>
