I've already figured this one out, but I'm posting my issue and the solution for the benefit of others. Here's the situation:
- I have a hosted layer A with fields [1, 2, 3] with a dependent view layer B showing all the same fields.
- From Pro, I overwrite layer A, including the new field 4 when doing so.
- On layer A, I configure the new field 4 to be visible, have certain domains, etc.
- On layer B, when I attempt to update the View Definition, field 4 does not appear in the list of available fields.
I attempted to use the arcgis.features.managers.FeatureLayerManager.add_to_definition() function to an identical JSON dict to the parent layer A, only to get the response that the operation was not supported on view layers.
How then, can I add an new, existing field from A to B?
