Using sql when I try to intersect a polygon with coordinates, when the projection is 3857 the intersect does NOT work, when the projection is 4326 wgs it works fine. The only difference between the FCs is the SRID. I projected FC PARCELS_TX 3857 to FC PARCELS_TX_WGS as a new FC and ran the same sql code and it returned a row as expected.
Below code using 4326 the intersect works
SET @lat = 32.288675
SET @long = -98.278444
DECLARE @g geometry = geometry::Point(@long, @lat, 4326)
/****** Script for SelectTopNRows command from SSMS ******/
select [Poly_MPARCELAPN]
,[Pt_STZIP4]
,[Pt_XCOORD]
,[Pt_YCOORD]
,[Shape]
FROM [GISDB].[dbo].[PARCELS_TX_WGS]
where @g.STIntersects(Shape) = 1
3857
Same code over table projected at 3857 does not return a result. It should return the same result as 4326
DECLARE @g geometry = geometry::Point(@long, @lat, 3857)
,[Pt_STZIP4]
,[Pt_XCOORD]
,[Pt_YCOORD]
,[Shape]
FROM [GISDB].[dbo].[PARCELS_TX]
