Model1
Good day,
I've created a model that uses species occurrence points to select specific polygons from a multipolygon shapefile. This works perfectly using the Select Layer By Location tool. I want to then join the information contained within the species occurrence points to the selected polygons to provide a final output of polygons which contain species occurrence points AND the information from the original species occurrence points. I believe that the Spatial Join tool is the most suitable for this.
As I have to do this for multiple species I have set up the Iterate Feature Classes command. The process runs fine but my problem is that the final output does not contain the information from the species occurrence points. When I open the Field Map of the Spatial Join tool, the only fields present are those from the multipolygon shapefile. My instinct tells me the problem lies with the Iterate Feature Classes command...
Any advice is highly appreciated.
