Hi all -
I'm repeatedly running into a problem using the "mosaic to new raster tool". Whenever I attempt to use this tool, the final raster has the wrong calculated statistics. I'm currently running ArcPro 2.5.2, however I've had this problem with ArcMap as well.
In this particular instance, I have 10 small rasters - they are 1 band, 16 bit unsigned. The calculated min and max values for the mosaic raster are well outside of the range of all the source rasters. I have tried using the "calculate statistics" and "build pyramids" tools, but neither change anything. The actual values of the mosaic raster are correct.
I've noticed that others have had this problem going back several years, but no solution appears to been found.
