Hi, Y'all,
I am working on Los Angeles Public transit system, and I try to create a network dataset using LA GTFS data to apply the network dataset in OD Matrix. For other cities, they have only one set of GTFS data for their public transit system, including Bus, Rapid Transit, Light rail, etc. However, for LA, there are two sets of GTFS, one for Bus and one for Rail. I created two separate network datasets for each of them, and I used the same street layer in both of them, and the result is similar (slightly different). In creating OD matrix, I was expecting to see the Rail network dataset to ate a few transit lines as LA has only 6 rail lines compared to many bus routes. But it wasn't. In both results nearly 40000 lines have been created (based on my origins and destinations). Can anybody clarify why there are similar and also what is the different between Rail and Bus gtfs in creating network dataset?
