Hello, I created a an Attribute rules - Constraint that avoid duplicate geometry (polygons) with same field attribute (N° Order), using Smart Editor the Constraint works perfectly. In the process it's needed split the polygon to do that I set the Edit widget however, when i use the cut tool one part of the polygon is delete of the database.
Anyone know what could be happening? the attribute rules works with edit widget?
thanks
