I needed to make changes to the JSON of an existing web map that is part of a web app. Before replacing it, I want to test the JSON changes on a new web map.
The new web map is a near duplicate the replacement--including its data sources, published services, and the layer ID. The main difference is in the itemIDs it uses to reference several feature layers.
The Web App uses a lot of configured widgets including different Searches, Group Layers, and the eSearch widget. I don't want to have to re-do any of those. Is there an easy location within the Web App's JSON I can change to point to the new web map instead?
