Hello,I currently have a query that will return 1 or multiple points. The problem I am having is getting the query to zoom to a single point. Here is my code, there is a valid feature set being returned: function showResults(featureSet) { //remove all graphics on the maps graphics layer map.graphics.clear(); //Performance enhancer - assign featureSet array to a single variable. var resultFeatures = featureSet.features; //Loop through each feature returned for (var i = 0, il = resultFeatures.length; i < il; i++) { //Get the current feature from the featureSet. //Feature is a graphic var graphic = resultFeatures; graphic.setSymbol(symbol); //Set the infoTemplate. graphic.setInfoTemplate(infoTemplate); //Add graphic to the map graphics layer. nameGraphic = map.graphics.add(graphic); //set map extent to selected features //This works if more than one point// //var myFeatureExtent = esri.graphicsExtent(resultFeatures); //map.setExtent(myFeatureExtent); onQueryComplete(resultFeatures); //Want to use this function to determine zoom } }I also have a function that can be used to zoom to the appropriate area: function onQueryComplete(returnedPointFeatureSet) { var featureSet = returnedPointFeatureSet || {}; var features = featureSet.features || []; var extent = esri.graphicsExtent(features); if (!extent && features.length == 1) { var point = features[0]; map.centerAndZoom(point, 3); } else { map.setExtent(extent); } }I'm having an issue with getting the onQueryComplete function to work properly. I don't see why it will not work. Any assistance is appreciated.Thanks,Geoff
