I have a dialog popup with a hyperlink. I want the popup to close when the link is clicked. I've tried "nboLink.on("click", closeDialog);" but the console says that this is not a function. Here is my code:
Layer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> name <SPAN class="operator token">=</SPAN> evt<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>NAME<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> nameNoDot <SPAN class="operator token">=</SPAN> name<SPAN class="punctuation token">.</SPAN><SPAN class="token function">replace</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="regex token">/\./g</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> nameDash <SPAN class="operator token">=</SPAN> nameNoDot<SPAN class="punctuation token">.</SPAN><SPAN class="token function">replace</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="regex token">/_/g</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"-"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> nameLower <SPAN class="operator token">=</SPAN> nameDash<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toLowerCase</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> nboLink <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"<b>${NAME}</b><hr><a target='_blank' href='</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fwebsite%2Fprofiles%2F" target="_blank">http://website/profiles/</A><SPAN>"</SPAN></SPAN> <SPAN class="operator token">+</SPAN> nameLower <SPAN class="operator token">+</SPAN>
<SPAN class="string token">"'><b>Profile</b></a>"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> popupContent <SPAN class="operator token">=</SPAN> esriLang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">substitute</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">,</SPAN>nboLink<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
dialog<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setContent</SPAN><SPAN class="punctuation token">(</SPAN>popupContent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
domStyle<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">set</SPAN><SPAN class="punctuation token">(</SPAN>dialog<SPAN class="punctuation token">.</SPAN>domNode<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"opacity"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.70</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
dijitPopup<SPAN class="punctuation token">.</SPAN><SPAN class="token function">open</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
popup<SPAN class="punctuation token">:</SPAN> dialog<SPAN class="punctuation token">,</SPAN>
x<SPAN class="punctuation token">:</SPAN> evt<SPAN class="punctuation token">.</SPAN>pageX<SPAN class="punctuation token">,</SPAN>
y<SPAN class="punctuation token">:</SPAN> evt<SPAN class="punctuation token">.</SPAN>pageY<SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">closeDialog</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
map<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">clear</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
dijitPopup<SPAN class="punctuation token">.</SPAN><SPAN class="token function">close</SPAN><SPAN class="punctuation token">(</SPAN>dialog<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
