Can a SimpleMarkerSymbol, created from an SVG path, be used as a renderer in LayerDrawingOptions for DynamicMapServiceLayers? See my example below. I don't get any errors. It simply doesn't show the SVG (red triangle) symbol for the fire station layer features - layer 7. The same SVG symbol displays fine if I apply it to a graphic and add the graphic to the map, but nothing appears when applied to a dynamic map service layer. My ultimate goal is to use custom SVG path text (e.g. "M100, 100......") with UniqueValueRenderer symbols.
<SPAN class="doctype token"><!DOCTYPE html></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>html</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>head</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>title</SPAN><SPAN class="punctuation token">></SPAN></SPAN>SVG render test<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>title</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>meta</SPAN> <SPAN class="attr-name token">http-equiv</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Content-Type<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">content</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>text/html; charset<SPAN class="punctuation token">=</SPAN>utf-8<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>meta</SPAN> <SPAN class="attr-name token">name</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>viewport<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">content</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>initial-scale<SPAN class="punctuation token">=</SPAN>1, maximum-scale<SPAN class="punctuation token">=</SPAN>1,user-scalable<SPAN class="punctuation token">=</SPAN>no<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>link</SPAN> <SPAN class="attr-name token">rel</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>stylesheet<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">href</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.17%2Fdijit%2Fthemes%2Fclaro%2Fclaro.css" target="_blank">https://js.arcgis.com/3.17/dijit/themes/claro/claro.css</A><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>link</SPAN> <SPAN class="attr-name token">rel</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>stylesheet<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">href</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.17%2Fdojox%2Fwidget%2FColorPicker%2FColorPicker.css" target="_blank">https://js.arcgis.com/3.17/dojox/widget/ColorPicker/ColorPicker.css</A><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>link</SPAN> <SPAN class="attr-name token">rel</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>stylesheet<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">href</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.17%2Fesri%2Fcss%2Fesri.css" target="_blank">https://js.arcgis.com/3.17/esri/css/esri.css</A><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="language-css style token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>style</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="selector token">html, body, #map</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="property token">height</SPAN><SPAN class="punctuation token">:</SPAN>100%<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN>100%<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">margin</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">padding</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>style</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN>
<SPAN class="language-javascript script token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>script</SPAN> <SPAN class="attr-name token">src</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.17%2F" target="_blank">https://js.arcgis.com/3.17/</A><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN>
<SPAN class="language-javascript script token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/Point"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/graphic"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/SpatialReference"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/Extent"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/Color"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/ArcGISDynamicMapServiceLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/SimpleLineSymbol"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/SimpleMarkerSymbol"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/symbols/SimpleFillSymbol"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/renderers/SimpleRenderer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/LayerDrawingOptions"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/config"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/_base/array"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/dom-style"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/domReady!"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>
Map<SPAN class="punctuation token">,</SPAN> Point<SPAN class="punctuation token">,</SPAN>
Graphic<SPAN class="punctuation token">,</SPAN> SpatialReference<SPAN class="punctuation token">,</SPAN> Extent<SPAN class="punctuation token">,</SPAN>
Color<SPAN class="punctuation token">,</SPAN> ArcGISDynamicMapServiceLayer<SPAN class="punctuation token">,</SPAN>
SimpleLineSymbol<SPAN class="punctuation token">,</SPAN> SimpleMarkerSymbol<SPAN class="punctuation token">,</SPAN> SimpleFillSymbol<SPAN class="punctuation token">,</SPAN>
SimpleRenderer<SPAN class="punctuation token">,</SPAN> LayerDrawingOptions<SPAN class="punctuation token">,</SPAN> esriConfig<SPAN class="punctuation token">,</SPAN>
arrayUtils<SPAN class="punctuation token">,</SPAN> domStyle
<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> app <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
app<SPAN class="punctuation token">.</SPAN>defaultExtent <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Extent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">97.78219462135767</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">30.25811946558375</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">97.6972260613063</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">30.30040143951408</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SpatialReference</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4326</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
app<SPAN class="punctuation token">.</SPAN>map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
extent<SPAN class="punctuation token">:</SPAN> app<SPAN class="punctuation token">.</SPAN>defaultExtent<SPAN class="punctuation token">,</SPAN>
sliderPosition<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"bottom-left"</SPAN><SPAN class="punctuation token">,</SPAN>
sliderStyle<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"small"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
app<SPAN class="punctuation token">.</SPAN>layerTestURL <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fservices.nationalmap.gov%2Farcgis%2Frest%2Fservices%2Fstructures%2FMapServer" target="_blank">http://services.nationalmap.gov/arcgis/rest/services/structures/MapServer</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">;</SPAN>
app<SPAN class="punctuation token">.</SPAN>layerTest <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ArcGISDynamicMapServiceLayer</SPAN><SPAN class="punctuation token">(</SPAN>app<SPAN class="punctuation token">.</SPAN>layerTestURL<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
app<SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>app<SPAN class="punctuation token">.</SPAN>layerTest<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
app<SPAN class="punctuation token">.</SPAN>layerTest<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"load"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="token function">resymbolizeTestLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">resymbolizeTestLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> iconPath <SPAN class="operator token">=</SPAN> <SPAN class="string token">"M100,100 L300,100 L200,300 Z"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> markerSymbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleMarkerSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
markerSymbol<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setPath</SPAN><SPAN class="punctuation token">(</SPAN>iconPath<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
markerSymbol<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setColor</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">220</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">20</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
markerSymbol<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setOutline</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> layerDrawingOptions <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> drawOpt <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerDrawingOptions</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
drawOpt<SPAN class="punctuation token">.</SPAN>renderer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleRenderer</SPAN><SPAN class="punctuation token">(</SPAN>markerSymbol<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
layerDrawingOptions<SPAN class="punctuation token">[</SPAN><SPAN class="number token">7</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> drawOpt<SPAN class="punctuation token">;</SPAN>
app<SPAN class="punctuation token">.</SPAN>layerTest<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setLayerDrawingOptions</SPAN><SPAN class="punctuation token">(</SPAN>layerDrawingOptions<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>head</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>body</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>claro<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>map<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>body</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>html</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
