If you use the Rectangle Text tool from the Draw toolbar to insert a text element then the text element created will support text wrapping.
However, if you use Insert | Text to insert a text element then the text element created will NOT support text wrapping.
Neither type of inserted text element has a property to toggle text wrapping on or off.
I've created quite a few text elements using the Insert | Text method because that is the method closer at hand when authoring maps and inserting all the other map surround elements. However, I've always been disappointed that these test elements did not support text wrapping. Now that I've become aware that the Rectangle Text tool supports this, I have the onerous task of creating new text elements and copying text into them. It would be much easier to just hit a checkbox and have text wrapping turned on.
