I want to migrate my project API from ver. 3.15 to ver. 4.x in order to support 3D sceneView. And during the work, I've found that I have no way to add Images (PNG format) onto the map using the new API.
I used to use MapImageLayer and addImage() function to do so, but there are no longer addImage() method within MapImageLayer Class. It seems that the defination of MapImageLayer in 4.x is different from it in 3.15. Is there anyone have encountered this issue? If so, could you please share how you have solved this problem.
Thanks.
