Greetings,
I am trying to get a basic sql statement working using arcpy.ArcSDESQLExecute, it keeps throwing an error.
I need to run an external sql with joins, etc in .sql file.
##The code
import arcpy,sys,csv
# Python environment
workspace = arcpy.env.workspace = r"C:\database_connections\K2_Master_Training.sde"
sde_conn = arcpy.ArcSDESQLExecute(r"C:\database_connections\K2_Master_Training.sde")
sql = "SELECT * FROM tbSite"
sqlresult = sde_conn.execute(sql)
for i in sqlresult:
print i
Get the following error??
AttributeError: AttributeError(u'ArcSDESQLExecute: SreamBindOutputColumn ArcSDE Error -65 \uec5c',)
If would appreciate assistance getting this working, to read a sql file.
Clive
