I would like to be able to uncheck the Filter By Extent box that is greyed out in the Infographic Widget configuration. I want my users to be able to filter based on an attribute and have the info graphic update for that filtered value, even if some of the points happen to be out of the current extent. This box unchecks itself if you load an extra data source into the InfoGraphic instead of a map layer. However, this is not a work around for me because the filter widget does not support filtering of extra data sources.
