I have a Map Series in which each page is a floor plan for different sites. Each site's plans are grouped by the site address. I've had a request for single pdfs from each site, where the output filename is the address. That single pdf should contain all the pages of floors from the site. I need to do this for nearly 100 sites. Currently the only way I can specify output filenames based on page number or name is to choose the "multiple PDFs" export options. If I use the address as the filename, it will create one pdf and continually overwrite each page with the same name. If I choose the single PDF export option, I have to specify the filename before the export, so I would have to do this manually for all the sites.
Here is a screenshot with an example. I want the pdf to be named "10625 SW 35TH AVE.pdf" and contain all eight pages for the Jackson site. I want to be able to do this as a single export resulting in a single pdf (with multiple pages) for each address group.
