This should be pretty easy, but I've tried a bunch of stuff and cant get it to work. How do I zoom to the newly outputted feature layer created by a geoprocessing service I create. Here is the code for I use to create it. I've tried the commented out method for setting the map's extent with the test1 and test2 variables, but it doesn't work.
-dave
function gpJobComplete(jobinfo) {
//get the result map service layer and add to map
gp.getResultImageLayer(jobinfo.jobId, null, null, function (layer) {
layer.setOpacity(0.7);
layer.id = "Created Mammal Data";
map.addLayers([layer]);
// var zoomLayer = map.getLayer('Created Mammal Data');
// var test1 = webMercatorUtils.geographicToWebMercator(zoomLayer.fullExtent);
// var test2 = zoomLayer.fullExtent;
// map.setExtent(test1, true);
map.on("layers-add-result", function (evtObj) {
domUtils.show(dom.byId('legendWrapper'));
if (!legend) {
var layerInfo = array.map(evtObj.layers, function (layer, index) {
return {
layer: layer.layer,
title: layer.layer.name
legend = new Legend({
map: map,
layerInfos: layerInfo
}, "legendWrapper");
legend.startup();
