A real time saver is missing from ArcGIS Pro 2.1 and previous versions....
Copy map to clipboard existed under the Edit menu in ArcMap, but no existing functionality exists in Pro. Using "Copy map to clipboard' and pasting into PowerPoint was the quickest way to build presentations. Turn off and on layers, zoom to a location, select copy map to clipboard and paste into your PowerPoint.
We need this function built into ArcGIS Pro. It could be a button on both the Share tab in the ribbon along with Print and Export. Exporting to a graphics file and inserting a picture in PowerPoint is too time-consuming along with managing all the files you create along the way.
