SQL Lite is the database format used by the Esri Runtime SDK's. When a replica is lost or corrupt on the server, there by breaking the link between server and local SQL Lite database, there is no way to synchronize edits between your local file and the server. If ArcGIS Pro (Desktop) could load a SQL Lite database, we could easily recover the data from the local offline database. As is, I have to use a SQL Lite database viewer and export the records to a CSV file, cleanup the Julian Dates in Excel, then import the tables to a file geodatabase in order to work with them.
