<SPAN class="comment token"># ---- Adding an axis parameter ----</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">normalize</SPAN><SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN> axis<SPAN class="operator token">=</SPAN>None<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token"># a is a (n x dimension) np.array</SPAN>
tmp <SPAN class="operator token">=</SPAN> a <SPAN class="operator token">-</SPAN> np<SPAN class="punctuation token">.</SPAN>min<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN> axis<SPAN class="operator token">=</SPAN>axis<SPAN class="punctuation token">)</SPAN>
out <SPAN class="operator token">=</SPAN> tmp <SPAN class="operator token">/</SPAN> np<SPAN class="punctuation token">.</SPAN>ptp<SPAN class="punctuation token">(</SPAN>tmp<SPAN class="punctuation token">,</SPAN> axis<SPAN class="operator token">=</SPAN>axis<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">return</SPAN> out
a <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>arange<SPAN class="punctuation token">(</SPAN><SPAN class="number token">25</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>reshape<SPAN class="punctuation token">(</SPAN><SPAN class="number token">5</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">5</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># ---- some data</SPAN>
array<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">4</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">[</SPAN> <SPAN class="number token">5</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">6</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">7</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">8</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">9</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="number token">10</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">11</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">12</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">13</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">14</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="number token">15</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">16</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">17</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">18</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">19</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="number token">20</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">21</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">22</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">23</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">24</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
normalize<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN> axis<SPAN class="operator token">=</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># ---- normalize by column</SPAN>
array<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0.25</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.25</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.25</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.25</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.25</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0.5</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.5</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.5</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.5</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.5</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0.75</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.75</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.75</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.75</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.75</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
normalize<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN> axis<SPAN class="operator token">=</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># ---- normalize by row</SPAN>
array<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">0.25</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">0.5</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">0.75</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">[</SPAN> <SPAN class="number token">0.31</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.06</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">0.19</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">0.44</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">0.69</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">[</SPAN> <SPAN class="number token">0.62</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.38</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.12</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">0.12</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">0.38</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">[</SPAN> <SPAN class="number token">0.94</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.69</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.44</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.19</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">0.06</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">[</SPAN> <SPAN class="number token">1.25</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.75</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.5</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.25</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
normalize<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN> axis<SPAN class="operator token">=</SPAN>None<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># ---- normalize overall</SPAN>
array<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.04</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.08</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.12</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.17</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0.21</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.25</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.29</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.33</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.38</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0.42</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.46</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.5</SPAN> <SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.54</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.58</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0.62</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.67</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.71</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.75</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.79</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0.83</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.88</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.92</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.96</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
