This comes up time and again. ....I have 'X' rasters for an area and I need to determine Y over time....
Here is an example.... ....calculating percentiles....
Cell Statistics... is the obvious choice. But you don't have the Spatial Analyst extension? Doesn't matter. All the tools that you need are already provided if you are using current versions of ArcMap or ArcGIS PRO.
Do some work
(1) Reading the raster files
<SPAN class="keyword token">import</SPAN> numpy <SPAN class="keyword token">as</SPAN> np
<SPAN class="keyword token">import</SPAN> arcpy
arrs <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
folder <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"C:\Data\rasters"</SPAN> <SPAN class="comment token"># ---- specify a folder containing all the rasters ----</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> folder
rasters <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListRasters<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"TIF"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> raster <SPAN class="keyword token">in</SPAN> rasters<SPAN class="punctuation token">:</SPAN>
arrs<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>RasterToNumPyArray<SPAN class="punctuation token">(</SPAN>raster<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
a <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>array<SPAN class="punctuation token">(</SPAN>arrs<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># ---- the master array ----</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Once the rasters are all converted to arrays, they were appended to a list. A master array was created in line 9.
As an example, 31 rasters in tif format were read in. These are small rasters, but they can be as large as you can process. You are now ready to calculate values for them using numpy.
(2) Getting the statistics
median = np.median(a, axis=0) # ---- pick a statistic ----
array([[ 59., 54., 36., ..., 57., 46., 46.],
[ 43., 45., 59., ..., 38., 51., 51.],
[ 35., 50., 57., ..., 47., 55., 65.],
[ 43., 52., 40., ..., 56., 62., 60.],
[ 45., 57., 39., ..., 45., 44., 48.],
[ 49., 57., 50., ..., 56., 50., 58.]]
mins = np.min(a, axis=0)
array([[1, 3, 0, ..., 6, 4, 5],
[1, 5, 6, ..., 6, 7, 2],
[3, 2, 4, ..., 2, 5, 4],
[4, 0, 1, ..., 3, 4, 6],
[0, 0, 0, ..., 5, 1, 0],
[4, 1, 1, ..., 0, 3, 7]])
# ---- name a statistic, with or without nodata values, it can be done ----<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Now when you are done your calculations you will probably want to make a raster so you can bask in the beauty of your efforts.
(3) Reading the raster information and saving the result
rast <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Raster<SPAN class="punctuation token">(</SPAN>r01<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># ---- read the first raster we loaded ----</SPAN>
rast <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Raster<SPAN class="punctuation token">(</SPAN>r01<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># ---- simple </SPAN>
dir<SPAN class="punctuation token">(</SPAN>rast<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># ---- get raster information... some snipping here ----</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'bandCount'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'catalogPath'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'compressionType'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'extent'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'format'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'hasRAT'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'height'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'isInteger'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'isTemporary'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'maximum'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'mean'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'meanCellHeight'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'meanCellWidth'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'minimum'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'name'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'noDataValue'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'path'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'pixelType'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'save'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'spatialReference'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'standardDeviation'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'uncompressedSize'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'width'</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="comment token"># ---- Save the result out to a new raster ------</SPAN>
r01 <SPAN class="operator token">=</SPAN> rasters<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="comment token"># --- rasters have the same extent and cell size</SPAN>
lower_left <SPAN class="operator token">=</SPAN> rast<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">.</SPAN>lowerLeft <SPAN class="comment token"># ---- needed to produce output</SPAN>
cell_size <SPAN class="operator token">=</SPAN> rast<SPAN class="punctuation token">.</SPAN>meanCellHeight <SPAN class="comment token"># ---- we will use this for x and y</SPAN>
f <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"c:\temp\result.tif"</SPAN>
r <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>NumPyArrayToRaster<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN> lower_left<SPAN class="punctuation token">,</SPAN> cell_size<SPAN class="punctuation token">,</SPAN> cell_size<SPAN class="punctuation token">)</SPAN>
r<SPAN class="punctuation token">.</SPAN>save<SPAN class="punctuation token">(</SPAN>f<SPAN class="punctuation token">)</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
(4) Saving and reloading the arrays
Now, the nice thing about arrays is that you can save a 3D to a file for reloading later (or any dimension for that matter).
If you have a 3D array like we have, this is kind of like a big 'zip'.
np<SPAN class="punctuation token">.</SPAN>save<SPAN class="punctuation token">(</SPAN>r<SPAN class="string token">"c:\temp\myarray.npy"</SPAN><SPAN class="punctuation token">,</SPAN> a<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># ---- 'a' is the multi dimensional array</SPAN>
a<SPAN class="punctuation token">.</SPAN>shape <SPAN class="comment token"># ---- 31 days, 100 x 100 cells </SPAN>
<SPAN class="punctuation token">(</SPAN><SPAN class="number token">31</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">100</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">100</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># ---- reload it </SPAN>
im_back <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>load<SPAN class="punctuation token">(</SPAN>r<SPAN class="string token">"c:\temp\myarray.npy"</SPAN><SPAN class="punctuation token">)</SPAN>
im_back<SPAN class="punctuation token">.</SPAN>shape
<SPAN class="comment token"># ---- check to see if it is good</SPAN>
np<SPAN class="punctuation token">.</SPAN>all<SPAN class="punctuation token">(</SPAN>a <SPAN class="operator token">==</SPAN> im_back<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># ---- some numpy magic ;)</SPAN>
<SPAN class="token boolean">True</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
That's about all. Not covered here is nodata cells (easy, you can assign one) and statistics for nodata (easy, every stat has a nodata equivalent).
Try your skills with the attached *.npy file.
