Hi all, running into an error and i'm not sure why when I am trying to rank the attribute field of a shapefile. I have a poly line shapefile of some streams that have an attribute field of some normalized data that is the data type of 'Double' and I am trying to rank these values by quartile. and store their rank in another attribute field. I know that you can use symbology > graduated colors > method: quantile with 4 classes and it is displaying my data correctly. However, I need to be able to have an attribute field with a rank to be able to use the data down the line.
I have been using python for my processes so far but I am currently running into an error and i'm not sure why/cant really find an answer online anywhere else. Here is a sample of my code
maximum = max(row[0] for row in arcpy.da.SearchCursor(NHDFlowline_HUC12, ['Normalized_Linear']))
print(maximum)
minimum = min(row[0] for row in arcpy.da.SearchCursor(NHDFlowline_HUC12, ['Normalized_Linear']))
print(minimum)
arr
= arcpy.da.
FeatureClassToNumPyArray(NHDFlowline_HUC12, (
'Normalized_Linear'))
p1
= np.
percentile(arr,
25)
p2
= np.
percentile(arr,
50)
p3
= np.
percentile(arr,
75)
p4
= np.
percentile(arr,
100)
with arcpy.da.
UpdateCursor(NHDFlowline_HUC12, [
'Linear_Rank',
as cursor
for row
in cursor
if minimum
<= row[
1]
<= p1
row[
0]
= 1
elif p1
< row[
1]
<= p2
row[
0]
= 2
elif p2
< row[
1]
<= p3
row[
0]
= 3
elif row[
1]
> p3
row[
0]
= 4
cursor.
updateRow(row)
first step should store a max and min value for the normalized data attribute and then create an array containing the values of my shapefile's attribute field 'Normalized_Linear' then the next steps are to assing values to p1 thru p4 as the breaks for the quartile and then use updateCursor to store in the rank. The resulting error is:
File "script path", line 143, in <module>
p1 = np.percentile(arr, 25, axis=None, out=None, overwrite_input=False, interpolation='linear', keepdims=False)
File "C:\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\numpy\lib\function_base.py", line 4269, in percentile
interpolation=interpolation)
File "C:\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\numpy\lib\function_base.py", line 4011, in _ureduce
r = func(a, **kwargs)
File "C:\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\numpy\lib\function_base.py", line 4386, in _percentile
x1 = take(ap, indices_below, axis=axis) * weights_below
TypeError: invalid type promotion
I am unsure of how to go about fixing this TypeError: invalid type promotion. I feel like it may have something to do with the data type being double but if so, I would like to know how to work around this.
Any help would be much appreciated
