Hello everyone,
The following source code shows how to copy features from one feature class (Source) to another feature class (Destination) when both features are versioned.And then remove features copied from the Source
The steps:
- create a new SDE version a WorkingVersion
- select Source Feature Class with features to be copied and make a Feature Layer
- select Destination Feature Class make a Feature layer
- ChangeVersion of both feature layers to the WorkingVersion
- append features to destination Feature Class
- delete features from Source Feature Class that were appended
versions = arcpy.ListVersions(database)
# Print the versions available to the user
for version in versions:
print(version)
if version == WorkingVersion:
# Execute DeleteVersion
arcpy.DeleteVersion_management(database, WorkingVersion)
# Execute CreateVersion
arcpy.CreateVersion_management(database, ParentVersion, WorkingVersion, "PUBLIC")
# Select records with STATUS = 'Completed' and Historical records
arcpy.MakeFeatureLayer_management(SourceFeatureCalss, SourceLayer, "STATUS = 'Completed'", "", " .....")
# Process: Make Feature Layer (2)
arcpy.MakeFeatureLayer_management(EditableFeatureClass, AppendedLayer, "", "", "......")
# Change Both layers SourceLayer and AppendedLayer To OWNER.WORKINGVERSION version
arcpy.ChangeVersion_management('SourceLayer','TRANSACTIONAL', WorkingVersion,'')
# Change to HISTORICALAASIS version
arcpy.ChangeVersion_management('AppendedLayer','TRANSACTIONAL', WorkingVersion,'')
# Process: Append...
arcpy.Append_management("SourceLayer", AppendedLayer, "TEST", "", "")
# Process: Delete Features...
arcpy.DeleteFeatures_management(SourceLayer)
arcpy.ReconcileVersions_management(database,
"ALL_VERSIONS",
"OWNER.ParentVersion",
"OWNER.WORKINGVERSION",
"LOCK_ACQUIRED",
"NO_ABORT",
"BY_OBJECT",
"FAVOR_TARGET_VERSION",
"POST",
"KEEP_VERSION",
scratchFolder + "RecLog.txt")
