I'm wondering if it's possible to publish 3D Geoprocessing service that returns a multipatch as the output feature?
I have run a 3D buffer tool on a few simple 3D points and created some buffered multipatch. This worked fine with Desktop applications (ArcScene and Pro). Then, I shared the result to the Portal and that also worked fine.
But, when I test the GP service using REST end point, the output feature seems not to have any geometry:
"paramName": "Output_Feature",
"dataType": "GPFeatureRecordSetLayer",
"value": {
"displayFieldName": "",
"geometryType": "esriGeometryMultiPatch",
"spatialReference": {
"wkid": 4326,
"latestWkid": 4326
"fields": [
"name": "OBJECTID",
"type": "esriFieldTypeOID",
"alias": "Id"
"name": "Name",
"type": "esriFieldTypeString",
"alias": "Name",
"length": 1024
"name": "BUFF_DIST",
"type": "esriFieldTypeDouble",
"alias": "BUFF_DIST"
"name": "BUFF_QUAL",
"type": "esriFieldTypeInteger",
"alias": "BUFF_QUAL"
"features": [
{"attributes": {
"OBJECTID": 1,
"Name": "Feature 2",
"BUFF_DIST": 50,
"BUFF_QUAL": 20
{"attributes": {
"OBJECTID": 2,
"Name": "Feature 1",
"BUFF_DIST": 50,
"BUFF_QUAL": 20
"exceededTransferLimit": false
}<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>The geometry type is recognized as "esriGeometryMultipatch". But, is the front-end (JS 4) able to use this result and display in a 3D Scene App?
Any examples with GP tools on 3D features? especially multipatch?
Thanks for any sugguestions
Regards,
Yao
