Usually when updating a URL on portal I use ArcGIS Online Assistant, it is a excellent resource for quick maintenance, but in this case I had to update hundreds of Web Maps and using AGO Assistant would have been time consuming.
I initially started by looking at the ArcGIS API for python version 1.6.2, but unfortunately I had no luck in updating the services with the API, so searching the web for a scrip to update web map services I found this one Example: Update the URL of a service in a web map—Portal for ArcGIS (10.7 and 10.7.1) | ArcGIS Enterprise but the script is still in python 2.7 and its end is near Python 2.7 Countdown.
So I took the time to update the script using the standard library as far as possible but I do like requests · PyPI to handle my web calls.
Well here is the result I hope someone finds it helpful
This Crawls trough all your portals content and updates the DNS
It goes without saying use with caution and at own risk.
# Original Source:
import urllib.request
import json
import requests
from urllib.parse import urlencode
import logging
import os
def header():
return {
'content-type': "application/x-www-form-urlencoded"
, 'accept': "application/json"
, 'cache-control': "no-cache"
def get_token(portal_admin_url, portal_username, portal_password, root_url):
# Generate Token
url = f"{portal_admin_url}/sharing/rest/generateToken"
payload = {
'f': 'json'
, 'username': portal_username
, 'password': portal_password
, 'client': 'referer'
, 'referer': f'{root_url}'
, 'expiration': '100'
return json.loads(
requests.request(
"POST"
, url
, data=payload
, headers=header()
, verify=False
).text
)['token']
def search_portal(portal_url, query=None, totalResults=None, sortField='numviews',
sortOrder='desc', token=None):
all_results = []
if not totalResults or totalResults > 100:
num_results = 100
else:
num_results = totalResults
results = __search__(
portal_url
, query
, num_results
, sortField
, sortOrder
, 0
, token
if not 'error' in results.keys():
if not totalResults:
totalResults = results['total'] # Return all of the results.
all_results.extend(results['results'])
while (results['nextStart'] > 0 and
results['nextStart'] < totalResults):
# Do some math to ensure it only
# returns the total results requested.
num_results = min(totalResults - results['nextStart'] + 1, 100)
portalUrl=portal_url
, query=query
, sortField=sortField
, sortOrder=sortOrder
, token=token
, start=results['nextStart']
return all_results
else:
logging.info(results['error']['message'])
return results
def __search__(portalUrl, query=None, numResults=1000, sortField='numviews',
sortOrder='desc', start=0, token=None):
'''Retrieve a single page of search results.'''
params = {
'q': query
, 'num': numResults
, 'sortField': sortField
, 'sortOrder': sortOrder
, 'f': 'json'
, 'start': start
if token:
# Adding a token provides an authenticated search.
params['token'] = token
return json.loads(
requests.request(
"POST"
, f'{portalUrl}/sharing/rest/search?'
, data=params
, headers=header()
, verify=False
).text
def webmap_get_data_or_info(webmapId, portalUrl, token, data_or_info):
# Query either the rest info or the rest data
try:
params = {
'token': token
, 'f': 'json'
logging.info(f'Getting Info for: {webmapId}')
item_data_req = requests.request(
"POST"
, f'{portalUrl}/sharing/content/items/{webmapId}{data_or_info}?'
, data=params
, headers=header()
, verify=False
).text
logging.info(item_data_req)
return json.loads(item_data_req)
except Exception as e:
logging.error(str(e))
def update_webmap_with_folder(webmapId, portalUrl, token, new_data, owner, folder=None):
# Update dns in webmap located in root or a folder
params = {'token': token}
data = {'text': str(new_data)}
folder = "" if folder is None else f"/{folder}/"
mod_request = f"{portalUrl}/sharing/rest/content/users/{owner}{folder}items/{webmapId}/update?" \
f"{urllib.parse.urlencode(params)}"
logging.info(mod_request)
# set verify to False if certificates are not valid.
try:
logging.info(
requests.request(
"POST"
, mod_request
, data=data
, headers=header()
, verify=True
).text
logging.error(e)
def update_webmap_service(webmapId, old_dns, new_dns, token, portalUrl):
'''Replaces the URL for a specified map service in a web map.'''
itemString = webmap_get_data_or_info(
webmapId
, portalUrl
, token
, '/data'
for layer in itemString['operationalLayers']:
try:
url = layer['url']
logging.info(f"Searching item ---- {url}")
logging.error(e)
return True
dns = str(url).split('/')
if dns[2].lower() == old_dns.lower():
dns[2] = new_dns.lower()
logging.info('/'.join(dns))
layer['url'] = '/'.join(dns)
item_info = webmap_get_data_or_info(
webmapId
, portalUrl
, token
logging.info(itemString)
logging.info('Updating: ' + item_info['title'])
webmapId
, portalUrl
, token
, itemString
, item_info['owner']
, item_info['ownerFolder']
def write_data(content):
# filter out esri_ accounts
# filter out false positive matches for web apps
data_to_write = [json.loads(json.dumps(item)) for item in content
if item['owner'][:5] != 'esri_'
or item['type'] != 'Web Mapping Application']
with open(f'{get_script_dir()}//content.txt', 'w') as content_file:
json.dump(data_to_write
, content_file
, indent=2)
def read_data():
# Reads item data and returns a list of item id's
with open(f'{get_script_dir()}//content.txt', 'r') as content_file:
data = json.load(content_file)
item_id = []
for record in data:
if record is None:
continue
item_id.append(record['id'])
return item_id
def setup_log(folder, level, filemode):
logging.basicConfig(
level=level
, filename=f"{folder}//log.txt"
, filemode=filemode
) if os.path.isdir(folder) else os.mkdir(folder)
def get_script_dir():
script_path = os.path.realpath(__file__)
working_dir = script_path.split('\\')[0:-1]
return '\\'.join(working_dir)
if __name__ == '__main__':
setup_log(
f'{get_script_dir()}\\log'
, logging.DEBUG
, 'w'
portal_url = 'https://gisportal.gauteng.gov.za/portal'
old_dns = 'gisportal.gauteng.gov.za'
new_dns = 'gisportal.gauteng.gov.za'
username = 'hlindemann'
password = 'Br@aks1809'
referer = 'https://gisportal.gauteng.gov.za/portal'
# Get a token for the source Portal for ArcGIS.
token = get_token(
portal_url
, username
, password
, referer
# Get a list of the content matching the query.
write_data(
search_portal(
portal_url=portal_url
, query='type:"Web Map"'
, token=token
input('Review content.txt before you continue')
for id in read_data():
id
, old_dns
, new_dns
, token
, portal_url
