I wish to use Spanish as the default language for Survey123. I am fine with everything except for when I want to have the "other" option available for the "select_one" or "select_multiple" lists. The default for "other" is in English. For the purposes of the survey, I do not need an English version.
Is there a way that I can specify the "other" to return in Spanish as well as the default box of "specify other"?
Can I do this without having to change the default language of the XML file?
Amy
