Dear all,
I would like to explore some Deep Learning demos in Python API documented here: Reconstructing 3D buildings from Aerial LiDAR with Deep Learning | ArcGIS for Developers
But the links there - for example in paragraph:
Complete data required to run this sample is packaged together in a project package and can be downloaded from here. You are also required to download the rule package used in Part 4 of this notebook from here.
Links for data dwonload leads to to Portal: https://pythonapi.playground.esri.com, which requires a login. Is this a problem with sharing settings on data items on the portal or do you have just stopped to provide these data to public?
Without data we cannot use demos properly.
Thank you.
Vladimir
