We recently had to update a survey to add a new question. As a result, we needed to delete/wipe the database and start with a fresh copy. I exported the existing survey (as a FGDB) and then moved it to a different folder, removed sharing, and renamed it (this survey has 150 records). I then updated the survey using the Survey123 application.
In survey123.arcgis.com, I can see the new survey (with 13 records), but other users who I have collaborated/shared the survey with are still seeing the 150 records. I have had the users delete their cache, sign in as incognito, etc., but they still do not see the new records of the updated survey.
Any thoughts/suggestions or is this an issue because I moved the feature service instead of letting the application delete it?
