Is there a way to make my widget look the same in Web Map Portal as it does in Web AppBuilder?
I am still very new to all this and although there are many things I like about building Widgets, I am still frustrated by what seems to this noobie as strange behaviors.
Is there anything I can or need to do on the Web Map Portal side or within the Widget code itself to make them appear and behave identically? I have attached the a display showing the displayed differences.
When the widget code is moved from the Web AppBuilder to the Portal Web Map, it seems to inherit or is overridden by behaviors on the Web Map side. For instance:
