Hi, I have a survey which uses repeats, and sums the total within each repeat using the aggregate function e.g. sum(${repeat_value}).
Since upgrading to Survey123 version 2.7.98 (and Survey123 Connect 2.7.72) this no longer works - the entry box remains blank. This worked perfectly in the previous version.
Is this a bug, or has the syntax changed somehow?
Thanks!
