I'm attempting to run a code sample for the ArcGIS API for Python Beta and am running into the following issue: when I try to render a map, it throws the error "invalid token" - despite being successfully get results via other operations like gis.users.get() and gis.content.search()
Stack trace is below (with account values replaced with 'zzzz')
RuntimeError Traceback (most recent call last)<ipython-input-15-6b70d1620c0f> in <module>() 1 from arcgis.gis import GIS 2 gis = GIS("https://zzzz.maps.arcgis.com", "zzzz", "zzzz")----> 3 map = gis.map('Seattle, WA', 6) /opt/anaconda3/lib/python3.5/site-packages/arcgis/gis.py in map(self, location, zoomlevel) 163 if location is not None: 164 if isinstance(location, str):--> 165 mapwidget.center = self.tools.geocoder.find_best_match(location) 166 elif isinstance(location, tuple): 167 mapwidget.center = location /opt/anaconda3/lib/python3.5/site-packages/arcgis/gis.py in geocoder(self) 648 try: 649 geocodesvcurl = self._gis.properties['helperServices']['geocode'][0]['url']--> 650 self._geocoder = Geocoder(None, geocodesvcurl, self._gis) 651 return self._geocoder 652 except KeyError: /opt/anaconda3/lib/python3.5/site-packages/arcgis/tools.py in __init__(self, item, url, gis) 71 } 72 #print(self.url)---> 73 svcprops = self._portal.con.post(self.url, params, use_ordered_dict=True) 74 collections.OrderedDict.__init__(self, svcprops) 75 try: /opt/anaconda3/lib/python3.5/site-packages/arcgis/_impl/portalpy.py in post(self, path, postdata, files, ssl, compress, is_retry, use_ordered_dict, add_token) 2523 postdata['token'] = newtoken 2524 return self.post(path, postdata, files, ssl, compress, -> 2525 is_retry=True) 2526 elif errorcode == 498: 2527 raise RuntimeError('Invalid token') /opt/anaconda3/lib/python3.5/site-packages/arcgis/_impl/portalpy.py in post(self, path, postdata, files, ssl, compress, is_retry, use_ordered_dict, add_token) 2525 is_retry=True) 2526 elif errorcode == 498:-> 2527 raise RuntimeError('Invalid token') 2528 self._handle_json_error(resp_json['error']) 2529 return None RuntimeError: Invalid token
