I have a complicated Survey123 that I need to transfer to another organization. I use the copy function in Online Assistant to transfer the feature service layer. However, the form and the service definition items are not available to copy. I've read that you can zip up the survey project folder, send it and then the new org can Create New Survey, from file. What about the connect to the feature service? Where do you update the url link? I'm still trying to understand the file structure and connections of Survey123. Any help is super appreciated. If it helps, both organizations are universities that do not run enterprise platforms. Thanks so much!
