Using a Survey with an existing feature dataset that is being displayed in a dashboard. The end users are able to update their project status. If project status is not 'Complete' they will be asked some questions.
Workflow example:
current year is set to 2020 and status is 'In Progress'
user is asked if their project will carryover into 2021
if Yes - modify date to 2021
Issue:
When I select my project (now 2021) I no longer want to see any of the modify date type questions.
The problem is I keep getting an error with the logic which I assume is because I am calculating the work plan year based on a yes/no question so I can't use that same value to hide fields.
Basically I want to be able to ask the questions if the work_plan_year = 2020 and the status != 'Complete' and then if the workplancarryover = 'Yes' update the work_plan_year to be '2021'.
It seems simple enough but I am stuck.
Joy
