I have an app I started building in QML.
I would like to have a runtime geodatabase install with the app for a small data query that I would like to be faster than using a service table.
Right now I am instantiating an feature layer object.
I create a Query Parameter object.
The problem is that the onQueryFeaturesResultsChanged is not an event for a feature layer. I try to set the property to the featureLayer.FeatureTable object but since this featuretable is a child of the featurelayer object, QML does not allow me to set it's onQueryFeaturesResultsChanged property. The data shows up and it seems to have the necessary data but I just cant get this query result event to work properly.
I have seen that the serviceFeatureTable object has onQueryFeaturesResultsChanged as an direct property instead of as a child of another property.
Here is how I instantiate my feature layer:
FeatureLayer { id:featureLayer
featureTable: gdb.geodatabaseFeatureTablesByTableName["EmergencyCallZones"]
Geodatabase { id: gdb
path: AppFramework.resolvedPathUrl(copyLocalData(inputGDB, outputGDB))
featureTable.onQueryFeaturesResultChanged: { eventCount = eventCount +1
coordinates.text = "clicked " + eventCount
Mind you this is not the only way I tried doing this but I think it is the most correct way and the way that should work.
Any help would be appreciated.
#appstudio qml,
