I am hoping that someone has a bright idea here, because I am out of them.
I have a Collector/Explorer app with a link on the pop up for the Parcel Layer, that parses the boundary coordinates to a geoshape question in Survey123 .. that bit works great.
What I want to do is in Survey123 is perform a reverse geocode on the Geoshape to get the street address. It would appear, obviously, that the pulldata("@geoshape",${location},"reverseGeocode.address.Street","https://xyz/server/rest/services/Locators/xyz/GeocodeServer") calculation doesn't work for a geoshape question.
So I came up with a solution to add a geopoint question inside a repeat (because you cant have a geoshape and geopoint in the same form unless one is in a repeat) and use that to reverse geocode on. Now that works in the form itself, so tick!.
Then I thought I could calculate XY centroid of the poly in Collector using Arcade, tick, then parse that to the geopoint question. HOWEVER, I have since found out that parsing information from Collector to Survey123 to questions inside a repeat isn't supported.
Anyone have any solutions? Any help would be greatly appreciated!
