I can get everything else returned except the maps. I know the page says its subject to change. Any ideas?
Seems this step might be the issue:
Enable map widget:
The ArcGIS Python API includes a map widget for embedding maps in the Jupyter notebook environment. To enable the map widget for all users, use the following command:
<SPAN class="hljs-selector-tag">python</SPAN> <SPAN class="hljs-selector-tag">-m</SPAN> <SPAN class="hljs-selector-tag">arcgis</SPAN><SPAN class="hljs-selector-class">.install</SPAN>
If you are on a Linux system and do not have permission to install the widget system-wide, you can install it in your local user profile by using the following command instead:
<SPAN class="hljs-selector-tag">python</SPAN> <SPAN class="hljs-selector-tag">-m</SPAN> <SPAN class="hljs-selector-tag">arcgis</SPAN><SPAN class="hljs-selector-class">.install</SPAN> <SPAN class="hljs-selector-tag">-u</SPAN>
You can now start using the ArcGIS Python API in your Python IDE of choice, or the Jupyter Notebook environment.
